CNN on DN not showing up?
Username: Foxtek
I'm running the Ariza 700 and all is running well with DN except for channel 200 (CNN). Anyone else have this issue?
Username: Banti
Post Number: 147
yup i had dis issue heres what i did, i did a factory defualt, and i did a blind scan again all channels were up and working!!
Username: Foxtek
Thanks Banti, I'll try that and I hope it works.
Username: Banti
Post Number: 149
yup hope so..im pretty sure it will
Username: Foxtek
Banti, I still have to try a blind scan tonight but in general, is it common for channels to just disappear like that? That channel was running fine and then it just vanished. Weird.
Username: Banti
Post Number: 150
yes this happens to me it happens when i have 2 satellites outside, every time i change the switch out side from 61.5 to 119, then it does a channel update, and it takes some of my channels out. i hate it but yeah it happens some times. u should try doing a factory settings then do a blind scan ull get all ur channels back.
Username: Kingusama
Post Number: 328
definitely try to scan it again
Username: Banti
Post Number: 186
yeah definetley
