Viper 350 HV
Username: Eurotrancegirl
Hi there,
I have to order new remotes for my Viper 350HV...does anyone here know to program the new remotes?
Thanks in advance!
Username: The_image_dynamic
San Diego
Post Number: 2795
Hi Lauren,
Open the door, turn the key on, push the valet button 1 time and release, then press and hold the same button in, you should get 1 chirp from the alarm... keep the button pushed and press the lock button on the remote you should get another confirmation chirp then you can release the valet button and turn the key off. That is how to program the viper remote for your model.
http://www.directeddealers.com/manuals/og/viper/G426V_07-05.pdf
Thank you for the response. I programmed my remote and I am good to go!
