New member Username: SlaindreamsPost Number: 8 Registered: Aug-07 | My friend ( since he is lazy and dosent wanna register for this forum ) wants to know... if he gets .. http://www.mtx.com/caraudio/products/enclosures/sledgeHammer9500.cfm ( the Dual 15"s ) and http://www.mtx.com/caraudio/products/amplifiers/thunder92001.cfm the Amplifier He wants to know if he gets those if he is gonna have to put in an Extra battery or whatever to power the whole system.. or if he can just hook the subs and Amp up and run it like that... |
Gold Member Username: CtmikeCt. Post Number: 5081 Registered: Feb-06 | he'll have to do some electrical upgrading. meaning alt. first and not just the battery. |
Silver Member Username: Thumpinwith8s2 RE8s,PG Xenon 400.1, 135.5dbs!!!! Post Number: 912 Registered: Jun-07 | I belive he will need 1>the big 3 2>HO alt 3>extra battery because he will be putting 2000rms watts in, but I may be wrong, wait for other replies before you rely on me. Anything over 1200-1500rms will usually need those things, depending on the vehicle that its going in. |
Silver Member Username: WojoproSummerville, SC Post Number: 355 Registered: Nov-04 | Yup... Upgrade the big 3 first. If you still see any dimming upgrade to a ho alt. |
Silver Member Username: Kyle_lowePost Number: 293 Registered: Apr-06 | i would guess a 200amp alt |
Silver Member Username: M0nkeyman692Post Number: 333 Registered: Feb-07 | ^^ u dont need one that big. im sure a 150 would do fine |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 12771 Registered: Jul-05 | "u dont need one that big. im sure a 150 would do fine" Get a 200+amp alt...Just make sure it does decent numbers at idle |
