Need 2 10's or 1 15"
Username: Cashby
DD 3512
Post Number: 416
I want some subs for my beater winter car this winter..I dont want to switch my stuff from my car now..SO i was planning on running 500rms-1000rms...I just want something good quality and strong and something kinda cheap..any ideas?? I want something louder then 1 15" CVR
Username: Theweasel
2 12 FI SSD, Colorado U.S. of A
Post Number: 1058
get a fi ssd 15"
Username: Cashby
DD 3512
Post Number: 417
little more then i wanna spend ryan..lil cheaper
Username: Theweasel
Post Number: 1059
15" cvr, that's a pretty good bang for your buck
Username: Cashby
DD 3512
Post Number: 418
thats wat i was thinkin to man..wat do u think i should feed it for power?? and wat should i tune it too..i listen to rap..maybe 40hz?
Username: Trevor_r
Bastrop, L.A Us
Post Number: 24
34 hz if u wanna hit lows when u get 2 40+hz ure edgin over 2 a spl setup
Username: Cashby
DD 3512
Post Number: 419
i want a mix of good lows and good highs..(i want sql...so would 38hz be good trevor??
Username: Rovin
4 10 Pioneer...
Post Number: 12118
y not get 2 12s cvr - would be louder than 1 15 .....
36hz is a good sql tuning IMO ....
Username: Evoixmr
Post Number: 109
whats your budget, and what amp will you be using?
Username: Evoixmr
Post Number: 111
wtf, my post was the 5th post how did it get way down here
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 4164
Get a 15" Treo ssx..they have nasty lows
Username: 04redmach1
Columbus, GA USA
Post Number: 1312
What kind of budget are you playing with?
Kevin
Username: Cashby
DD 3512
Post Number: 420
o idk...kevin dont u have classics and stuff like that?? how much those run?? or whats your line up for subs?? Prices....
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12752
I will sell you a Fully loaded BL for $250shipped
Username: Santa_fe
Post Number: 113
cody i got two cuspid subs chillin in the closet....the cones have a small dent in them but it doesent affect quality...its more of an astetic thing....and theses would go in beater any way right??? i got a real old double ten box ill toss in for like nothing ......give me an offer
