Double channels after blindscan...?
Username: Shadow45
Monterrey, Nuevo Leon Mexico
Post Number: 47
Can someone tell me why this happens?, ive tried satscan and blind scan and both give me double channels and also im missing some of the premium ones like MAX and 1-2 from Showtime...thanks
Username: Viruscauser
Leesburg, Georgia
Post Number: 160
Is it possible that you have Dish 500 or Dish Pro but you're scanning with the LNB set to Standard?
You did not say anything about which box or which bin you're using. Specify everything so that someone with the same setup can jump in and give you a better answer.
Username: Shadow45
Post Number: 49
thanks answering, but i figured out,for some reason after the conversion to 2700 it set up , what it looked to me the wrong config, it put the 110 in diseqc #2 when it should have been in #1 and the 119 as #1...
Anyhow i changed them back to where they should have been, reseted the box and did a blind scan..problem was fixed afterwards.
