My friend wants to know.....
Username: Slaindreams
Post Number: 8
My friend ( since he is lazy and dosent wanna register for this forum ) wants to know... if he gets ..
http://www.mtx.com/caraudio/products/enclosures/sledgeHammer9500.cfm
( the Dual 15"s ) and
http://www.mtx.com/caraudio/products/amplifiers/thunder92001.cfm
the Amplifier
He wants to know if he gets those if he is gonna have to put in an Extra battery or whatever to power the whole system.. or if he can just hook the subs and Amp up and run it like that...
Username: Ctmike
Ct.
Post Number: 5081
he'll have to do some electrical upgrading. meaning alt. first and not just the battery.
Username: Thumpinwith8s
2 RE8s,PG Xenon 400.1, 135.5dbs!!!!
Post Number: 912
I belive he will need
1>the big 3
2>HO alt
3>extra battery
because he will be putting 2000rms watts in, but I may be wrong, wait for other replies before you rely on me.
Anything over 1200-1500rms will usually need those things, depending on the vehicle that its going in.
Username: Wojopro
Summerville, SC
Post Number: 355
Yup... Upgrade the big 3 first. If you still see any dimming upgrade to a ho alt.
Username: Kyle_lowe
Post Number: 293
i would guess a 200amp alt
Username: M0nkeyman692
Post Number: 333
^^ u dont need one that big. im sure a 150 would do fine
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12771
"u dont need one that big. im sure a 150 would do fine"
Get a 200+amp alt...Just make sure it does decent numbers at idle
