Amps for sale. Zapco, Kicker, Xtant, Crossfire, EarthQuake
Username: Van_man
Boston South, MA
Post Number: 2809
Selling a bunch of stuff.
First of,
Zapco Z100C2 2 x 50W at four. 1 ohm Stable. $60
Xtant 404M $150
Crossfire CFA15HC $150
EarthQuake PA-4050c $100
Kicker ZR 120 $125
Kicker ZR 240 $175
All prices include shipping.
Heres some specs of them.
Zapco
25x2 at 4
50x2 at 2
100x1 at 4
(Actuall Amp is in better condition then pic represents)
Crossfire. (stole description from Ebay)
Up for grabs is one AWESOME Amplifer, a Crossfire Audio CFA 15 HC. This amp is BRAND NEW in the box, not refurbished, with manuals, and accessories. Please do not mistake this equipment with the entry level Crossfire stuff you see listed right now on eBay. Back in the late 1990s Crossfire Audio was a new company trying to make a name for themselves in the ultra competitive IASCA circuit. They created the HC line to be able to compete. Back then, the lanes were being ruled by the High Current (HC) Cheater Amps like the Orion HCCAs and Precision Power Pro Mos Lines. These amps are rated at lower power at 12.5 volts, but with unregulated power supplies and the ability to handle, 1 ohm and 1/2 ohm loads could produce incredible amounts of power! This is exactly what you have here. The other Crossfire amps listed now would burn up in two seconds if you tried to wire them in loads that these amps can handle all day! I am going to go into a very detail description of the specs because most people are not aware that these were ever made. Look at the specs below and compare them to the highest quality amps ever made, those Orions, Precision Power, Rockford Fosgate, Zapco and JL Audio. You will see these rate as good or better! Check out the Damping Factor!!
Fully 1/2 Ohm Stable Stereo Operation / 1 ohm Bridged in High Current Mode
Military Spec Audiophile Grade Components
High Efficiency Mosfet Power Supplies -IRFZ44 MOSFET transistors
Oversized Capacitor Banks
Wire Free PC Board Layouts
Gold Plated Input and Output Connectors
Variable Highpass or Lowpass Electronic Crossover
Switchable High Current/High Power Mode
Variable 45Hz Boost
RCA Preamp Output
Simultaneous Mono/Stereo Operational Capability
Internally Bridgeable
5 way Protection Circuitry
Soft Remote On/Off Circuitry
High Current/ High Power
RMS Power:
4 ohms @ .008% THD 15 x 2 / 30 x 2
2 ohms @ . 02 % THD 60 x 2 / 110 x 2
1 ohms @ .02 % THD 110 x 2 / 185 x 2
1/2 ohms @ .02 % THD 185 x 2
Bridged output @ .02 % THD 370 x 1.......WOW~
Signal to Noise > 100db
Channel Separation > 70db
Damping Factor 400
Input Sensitivity 340mV - 5.2V
Input Impedance 20K ohms
Power Fuse 40 Amp
Dimensions 9.6W x 2H x 13L
Subsonic Filter 22Hz @ 12dB
45Hz Boost Switch 0- +12dB
X-OVER SLOPE 12 dB
ALL SPECIFICATIONS ARE WITH 12.5 VOLTS DC. TYPICAL OUTPUT WITH 14.4 VOLTS DC IS 15% TO 20% HIGHER.
EarthQuake. Google for specs.
Xtant 404M Google for specs
Kicker ZR 240
ZR240:
60 watts rms *2 @ 4 ohms
120 watts rms *2 @ 2 ohms
150 watts rms *2 @ 1 ohms
240 watts rms *1 @ 4 ohms bridged
300 watts rms *1 @ 2.66 ohms bridged
300 watts rms *1 @ 2 ohms bridged
frequency response 10Hz - 28,000 (+/-0-1db)
sound/noise ratio > 100db (unweighted @ rated power)
http://www.kicker.com/06/tech-support/manuals/manuals/ZRAmpsMan.pdf
Kicker ZR120
Username: Charlesbhs
Dallas, Tx USA
Post Number: 264
how much for the sub and box?
Username: Jkidder
IA, DP RD
Post Number: 1867
nice amp
Username: Kewinn89
G-Bay, Alabama Usa
Post Number: 145
i'm interested in the earthquake amp i can't find the specs n e where though
Username: Van_man
Boston South, MA
Post Number: 2823
JL sub 12 W6 V2
$230 shipped
Ported box for it. $50 plus shipping (its heavy)
PG Comps $170 Shipped. (bran new tweeters, never used)
Ill find the specs for you on the earthquake.
Username: Van_man
Boston South, MA
Post Number: 2824
earthquake 50 x 4 at 4 ohms
560 w at 2 ohms
Username: Th3pwn3r
Post Number:...
Post Number: 4731
I'll probably take the PG comps but look at this link and let me know if these are the set you're selling
http://woofersetc.com/index.cfm?fuseaction=product.display&product_id=1236
If those are the ones I'll take them probably next Friday.I also need to talk with you about them about what had happened.Thanks Marc.
Username: Johnfiac
A-ToWn, 9515 thumpin... What u bumpin?
Post Number: 3494
Rob arent you getting low on power yet.....
maybe now?
haha j\p what kinda alt. do u have... your nearing 5-6K now arent u?
Username: Th3pwn3r
Post Number:...
Post Number: 4756
I'd say closer to 8Krms.Maybe more.I have a 300amp Iraggi Alt and 2 Kinetik HC2400s and dual runs of 1/0 Kolossos Kable for power and grounds and I have 1/0 grounds everywhere.I drop when I slam it super hard but my Kx1200.1s are pretty efficient.I've only seen it drop below 12 volts once and I had been burping it for a bit.I need to install an HC1800 under the hood and run a couple more grounds here and there and my charging will be even better.I usually don't drop below 13.8 and now that I think of it...I've seen my voltmeter drop to 11.9 at the lowest and it's .2 volts under what it should be so I've never actually dropped below 12volts(I tested with a DMM).I should be alright with running another 3-400 watts rms :-)Don't worry though Killa,I have some plans.
Username: Th3pwn3r
Post Number:...
Post Number: 4757
The reason I say closer to 8k is because I'm running them below the rated ohm load.The amps are seeing a 1.33 ohm load and the amps are strapped.
Username: Th3pwn3r
Post Number:...
Post Number: 4758
Oh and Marc...sorry to say but after thinking about what you told me last night I'm going to run some different comps =/ I really wanted those but our talk changed my mind...let's just say I'm too cheap? ^_^
Username: Van_man
Boston South, MA
Post Number: 2843
Zapco Z100C2 2 x 50W at four. 1 ohm Stable. $55
Xtant 404M $150
Crossfire CFA15HC $120
EarthQuake PA-4050c $80
Kicker ZR 120 $115
Kicker ZR 240 $150
