I was having the exact same thing happen with my 2700A. Found out the bin file had been updated again. Try reloading the bin file. Now, I have a question. My levels and quality are all good. But I'm getting a lot of "scrambled or bad channel" any ideas?
If you have are getting some scrambled channels, please follow these steps:
- Go to any scrambled channel - Wait 10 seconds - Directly, unplug the receiver power cable from the power switch (wall switch). You don't have to turn it OFF from remote, just simply unplug it from the wall while it's ON. - Wait 20 seconds - Plug the cable back into the wall - Wait for the receiver to boot up
Do a factory reset, which will delete all the channels, then fix your ANTENNA SETTINGS and make sure they are correct. Then, re-scan your satellite(s) and see if that solves your problem.
if I reset the factory settings, is it going to go back to the original bin file? I tried once before, and had to have a friend reinstall all the channels. Wouldn't find anything when I scanned.
factory settings, will not remove any files, but you will need to do your antenna settings and any other initial setup. then you will need to scan the sats.
