Pansat 2500a
Username: Fongman312
Hi,
Using a Pansat 2500a.
I entered the most recent keys I could find for D!sh, but once I got to watch the channel nothing happens but autoscrolling. It says that it is "generating the image" or something like that. Could someone explain, or give me a way to fix it? I'm trying to learn all this stuff on the fly.
Thanks
Username: Viruscauser
Leesburg, Georgia
Post Number: 201
What bin are you using? Is your autoroll set to OFF?
bin? sorry, I'm learning all of this. How do I set auto roll to off? much appreciated!
Username: Jagga
Post Number: 33
Hello guys
can anybody help me downloading BIN 294T for Pansat 2500
thanks
Leesburg, Georgia
Post Number: 203
Phong Nguyen go to Menu, scroll down to system information and tell us what you see.
Username: Banti
Post Number: 155
yes jagga sing u can get the loader at dsstester*com and the bin at dsscentral*com all u gotta do is unzip the fil and select the com port ud like select the bin connect the modern cable rs232 and then write the bin..thats all to it but to do it!!>
Username: Rtap
FL
Post Number: 374
Ariza Ultra 400/500- Null
Astrovox 2600-Straight DB9
Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, ,etc.)-Null
Co0lsat 4000 Plus-Null
Co0lsat 4000 Pro-Straight DB9
Cooltec-Null
Coship (All)-Null
Digiwave 6800/7000-Null
Digiwave Diamond-Straight DB9
Dreambox (All)-Null
Fortec lifetime-Straight DB9
Fortec Lifetime Ultra-Straight DB9
Lava 2600-Null
Max 2500-Null
****sat (All)-Straight DB9
Microroyal (All)-Null
Pansat 2300a/2500a and all clones-Straight DB9
Pansat 2700-Null
Pansat 3500-Null
Pansat 5000HC-Null(Also can program through USB)
Pantec/Multistar Max (All)-Null
Pantec/Multistar MS (All except MS1000)-Straight DB9
Pantec MX/Ultra-Straight DB9
Rex1-Null
Silver bullet/ST 1000/2000-Null
Skyview 500-Straight DB9
Spacestar DVB500-null
Stealth 2000a-Null
Ultrastar 5000-Null
Viewsat VS2000-Null
List of Popular Receivers Firmware Cable
NULL MODEM CABLE (Cross over )
* Ariza Ultra 400/500/700/750/800 & Extreme - Null modem cable
* Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II. MS1000, ,etc.)- Null cable
* Bluejay 1 & 2 -Null modem cable
* Buzz S2010F - Null modem cable
* Captive Works 1000s (CW500s,CW600s, CW600s Premium) - Null
* Co0lsat 4000 Plus-Null
* Cooltec ( Clones only ) - Null
* Coship (All)-Null
* Digiwave 6800/7000-Null
* Dreambox (All)-Null
* ExtremeView Magnam XV3300 - Null
* Koolsat/Sonicsat (clone) - Null
* Kusat Pro 2600a - Null
* Lava 2600-Null
* Max 2500-Null
* Microroyal (All)-Null
* Neusat SP6000 ( SP6000 Premium ) -Null (Also can program through USB)
* Orasat v5- Null
* Pansat 2700-Null
* Pansat 3500s/sd - Null Cables - (Also SD Memory Card)
* Pansat 5000HC-Null modem cable(Also can program through USB)
* Pantec/Multistar Max (All)=Null
* Rex1-Null
* Silver bullet/ST 1000/2000-Null
* Skyview RX600 - Null
* Spacestar DVB500-Null
* Stealth 2000 * Techsat - Null
* Ultrastar 5000-Null
* Viewsat VS200- NULL -------------------------------------------------------------------------------- -------------------------------------------------------------------- STRAIGHT THROUGH CABLE
Astrovox 2600-Straight through DB9
Co0lsat 4000 Pro/5000Pro/5000Platinum/6000Premium-Straight DB9
Cooltec ( Non Clone ) -Sraight through DB9
Fortec lifetime-Straight through DB9
Fortec Lifetime Ultra-Straight through DB9
lava 3200- straight through db9
Megasat (All)-Straight through DB9
Pansat 1500a/2300a/2500a and all clones-Straight DB9
Pantec/Multistar MS (All except MS1000)-Straight through DB9
Pantec MX/Ultra-Straight through DB9 Skyview 500-Straight through DB9 Andy
110/119
Quad LNB can do with no additional switches
1 coax cable straight to each receiver
Username: Banti
Post Number: 159
thankss!!!
