Help Pansat 2700a - Constant picture cycle
Username: Jimminiquick
Pansat 2700a continually cycles through "wait for picture" screen
keys are up to date, signal quality and strength are well, im left clueless....
any ideas??
Username: Asharfi
Post Number: 753
Please switch OFF your receiver from the back switch. Then, please wait 10 - 20 seconds and then, turn your receiver back ON.
Continues to cycle through wait for picture
Username: Wakenbake
Post Number: 335
is the autoroll off, if not turn it off
with autoroll off "bad or scrambled" message appears
signal is still strong
Level 74-77%
Quality 98-99%
Username: Asharfi
Post Number: 755
Keeyp the autoroll turned OFF and re-enter the keys, but first set it to Set Daufault Key.
Username: Tony4564
I was having the exact same thing happen with my 2700A. Found out the bin file had been updated again. Try reloading the bin file. Now, I have a question. My levels and quality are all good. But I'm getting a lot of "scrambled or bad channel" any ideas?
Username: Delgado258376
Monterrey
Post Number: 222
me too, any idea please..
Username: Steph_raven
Cartier is my boy toy!..., U wanna play... Canada
Post Number: 157
if you guys are running bev then yes for all ppv and some channels like tsn. for dn sorry can't help i'm not set up for dn
Username: Asharfi
Post Number: 759
For Dishnetwork People:
If you have are getting some scrambled channels, please follow these steps:
- Go to any scrambled channel
- Wait 10 seconds
- Directly, unplug the receiver power cable from the power switch (wall switch). You don't have to turn it OFF from remote, just simply unplug it from the wall while it's ON.
- Wait 20 seconds
- Plug the cable back into the wall
- Wait for the receiver to boot up
That'll solve your problem!
Monterrey
Post Number: 225
AV - I Did and still with the same message, "bad or scrambled"
Monterrey
Post Number: 227
I got signal.
Thanks
Username: Tony4564
I tried that....twice, and still have the same problem.
Username: Wakenbake
Post Number: 336
bad / scrambled channel, set default key, see if it helps
Username: Tony4564
tried, no good
Username: Asharfi
Post Number: 761
Do a factory reset, which will delete all the channels, then fix your ANTENNA SETTINGS and make sure they are correct. Then, re-scan your satellite(s) and see if that solves your problem.
Username: Tony4564
if I reset the factory settings, is it going to go back to the original bin file? I tried once before, and had to have a friend reinstall all the channels. Wouldn't find anything when I scanned.
Username: Wakenbake
Post Number: 347
factory settings, will not remove any files, but you will need to do your antenna settings and any other initial setup. then you will need to scan the sats.
