Silver Member Username: NorthomahaPost Number: 514 Registered: Mar-06 | how do i wire 4 alpine type r dvc 2ohm subs at 1 ohm on this amp? |
Bronze Member Username: Mark8722 Type X 12s, Hughes S..., Texas Post Number: 69 Registered: Jul-07 | http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=4&woofer_imp=3 |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4673 Registered: Jul-06 | You probably shouldn't be wiring it if you don't know how =/ I can't imagine what other things you don't know how to do. Run the subs VCs in series and then the subs all parallel from the amp. |
Silver Member Username: NorthomahaPost Number: 518 Registered: Mar-06 | i know how to do that,....ROB. but theres some funny business about it producing 4000rms at 2ohm. 2000-Watts RMS x 2 @ 1-Ohm 4000-Watts RMS x 1 @ 2-Ohm here check out the chart on autoteks website. http://www.maxxsonics.com/autotek/mm_amps_SuperD.html does this mean it just has a regulated power supply that produces 4000 watts at either impedance for installation flexibility or whats the deal. im confused. |
Gold Member Username: SouthernrebelMonroe, Louisiana 2 DD3515s, 1... Post Number: 5211 Registered: Mar-04 | C.Reming, You are not going to be able to get the full 4000wrms out of that amp w/ your subs. You would need four DVC 4ohm subs to get a 2ohm mono or 1ohm stereo load. As is sits now, you can get 2ohm stereo or 4ohm mono to an mm4000.1d. That will give you ~1400w x2 or 2800w x1. |
Silver Member Username: NorthomahaPost Number: 523 Registered: Mar-06 | yea, we changed amps to the rockford t40001bd |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4733 Registered: Jul-06 | Nice.That sh1t is gonna slam |
Gold Member Username: Trey4sportsPost Number: 1702 Registered: Sep-06 | canaan, i think that amp is just a single channel. it has two internally paralled amps. |
Silver Member Username: NorthomahaPost Number: 524 Registered: Mar-06 | thats what i was thinking, almost like the massive audio 3000.1 |
Gold Member Username: SouthernrebelMonroe, Louisiana 2 DD3515s, 1... Post Number: 5213 Registered: Mar-04 | No...its a "dual mono". 1 board...2 channels. Pretty much a 2ch class D amp. |
Silver Member Username: NorthomahaPost Number: 527 Registered: Mar-06 | so youd wire it as if it were two seperate 2000watt mono amps? |
