Help please
Username: Rated337
I have a view sat platinum, some channels dont get good signal. Most of the showtimes,starz and Espn's channels are breaking up real bad. they worked fine before i had to put in a new bin DBPSW_070817P. I've just recently started uploading bins, before i would just type in the keys. Any idea on whats the problem? Is it the bin? Thanks
Username: Banti
Post Number: 96
wrong bin this is for extreme
Username: Silver1123
Mexico, DF Mexico
Post Number: 144
Go here
http://ftabins.net/forumdisplay.php?f=112
Register, its free, and download the latest bin for your reciever.
That should help.
If not, check the sw 21 switch.
