DVR SETUP
Username: Jdill001
Hello,
I have a digital cable box, Pioneer DVR, and Pioneer AMP/Reciever, I currently have the DVR setup to record the channel i am currently watching, but the DVR has the capability to record channels imi not currently watching. what is the best way to set it up?
Username: Samijubal
Post Number: 3702
You can only record the channel you're watching if it's a digital channel. You can record analog channels you're not watching.
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 471
Your cable box can only tune to one chanel at a time, but if you split the RF antenna cable befor the cable box and allow your set up as is to stay and add a RF antenna cable from the split directly to the DVR you may be able to record non scrambled chanels. Or add a roof antenna to record local stations while watching cable or visa versa.
