1100d Directed
Username: Santa_fe
Post Number: 82
Does anyone know any spces on this amp it is a 2000 so it may be a little shaky but i may be able to get it for free soo worth a shot right???
Username: Loudon
Post Number: 1670
its from 2000? directed was alot better back then ... but there solid amplifiers i wouldnt worry man especially if its free ... ill buy it for 35 shipped if it works :-)
Username: The_image_dynamic
San Diego
Post Number: 2758
Output Power (Resistive) (2 ohms @ 60 Hz to 1% THD+N): 768 watts @ 14 volts; 634 watts @ 12.8 volts; 427 watts @ 10.5 volts
Output Power (Resistive) (1 ohm @ 60 Hz to 1% THD+N): 1072 watts @14 volts; 895 watts @ 12.8 volts; 603 watts @ 10.5 volts
Output Power (Reactive) (2-ohm IHF Load @ 60 Hz to 1% THD+N): 808 watts
Crosstalk @ rated output, 20 Hz to 20 kHz: N/A
Damping Factor @ 100 Hz: 42
Voltage for Rated Output: 153mV to 7.8V
Idle Current Draw: 2.6 amps
Current Draw @ 1/3 Maximum Power: 35 amps @ 357 watts
Efficiency @ 1/3 Maximum Power: 73%
Power-Up Noise: 40.3 dB SPL
Username: Santa_fe
Post Number: 84
so brad it wont push 4ohm subs cuz thats what i got.....and are we sure this is the same amp..cuz the one i got here is 2 channel....im thinkin thoes are the specs for a mono amp?? not the tow channel one
San Diego
Post Number: 2773
The DEI 1100D is a mono amp. Maybe you are confused because it has two sets of speaker outputs? Also, those specs were a test of the amp by Car Sound & Performance and those were the actual numbers they got out of it. Not sure why they didn't include the specs but it will also do 425@ 4 ohms.
http://www.carsound.com/review_archive/amps/dei1100d.html
http://www.cardomain.com/item/DEI1100D
Username: Santa_fe
Post Number: 87
so even tho this amp has two channels one channel for two wires and another channel for two more wires this amp wont support two subs at 4ohms....hope i got all that right...im kinda new and trying my best to catch on! so that 425 is both channels together right???? so if it can run two subs it would be like 212 rms for each channel??? Im kinda confused lol...why would they make a mono amp with two channels??? why not just one channel with 425 instead of bridging two channels to get the 425?
Username: Santa_fe
Post Number: 88
help me here guys i gotta know pretty quick!!!!!
Username: Bernymac
BME
Post Number: 3256
http://www.bcae1.com/bridging.htm
I took the time to find that for you. So it would be nice if you read it.
Username: Santa_fe
Post Number: 90
ok will do
