Do DTV 3LNB dishes work with FTA receivers? I have a viewsat ultra and was attempting to connect to a DTV AU9 Dish with 3 LNBs, but did not receive a signal. The receiver does work but I was considering getting a Dish with multi LNB's. If it does not are there any recommendation?
Here is a list of sites where you will find a lot of information. It has been modded. from a list published here.
Future FTA - Blacklist's Site: [link removed] (C00LSAT and All receivers) DSS Newbies: [link removed] (Pantecs,all clones and all receivers)
File Share Site - No Registration Required: -------------------------------------------------- Good for gettting Original factory firmware: [link removed]
Best site for DISHNET info, channels, transponders and changes etc.. [link removed] [link removed] [link removed]
- Yo need to set LNB to universal - If you point middle LNB to 101 (you'll get 91 and 110) - If yo point to 110 (you'll only get 119) - Yo'll never get 110/119 with these LNBs (either or)
- The reason is Middle LNB has an internal block to most higher transponders) It will allow yo to get 3 or 4 transponders with very limited channels on middle LNB
