PanSat 3500sd Assistance Needed
Username: Jryevols
Little rock, Arkansas USA
Post Number: 21
Just received new Pansat 3500sd. I am told by seller that Imust download software to get Dishnet. The last Pansat 3500sd that I received all I had to do was load in bin numbers manually. Can anyone tell me where I get the software that will open the autoroll , nagravision or I guess it is called the CAS System. Thanks
Username: Nbn
Post Number: 61
Is it a real pansat ? I have a clone and use the vortex 3500 SD bin. It works flawless, found at ftabins.net
Username: Lklives
Post Number: 11580
Yes Vortex emailed us that 3025 bin awhile back...its posted in the CLONES section at dsscommunity.co*m also...the clone 35.01 loader is there too ...works great on all 3500 and clones..
also have the Vortex 2700 clone bin 2008 for all 2700's and their clones....with clone loaderr 27.02.....and also have the clone 2700 b75 boot upgrade entire package
[link removed]
Username: Nydas
Post Number: 3577
Here is a list of sites where you will find a lot of information. It has been modded. from a list published here.
Future FTA - Blacklist's Site:
[link removed] (C00LSAT and All receivers)
DSS Newbies:
[link removed] (Pantecs,all clones and all receivers)
File Share Site - No Registration Required:
Good for gettting Original factory firmware:
[link removed]
Best site for DISHNET info, channels, transponders and changes etc..
[link removed]
[link removed]
[link removed]
Username: Nydas
Post Number: 3578
[link removed]
