Sundown
Username: Mike11mac11
Grand rapids, Michigan Usa
Post Number: 36
hey just wondering if anyone is selling a sundown SAE-1000D if so hit me up
thx
Username: Extrmndor3
Post Number: 6738
how about a hifonics bxi1606d????? less money and lil more powa :-) theres more choices tho
Post Number: 37
is that a good amp (better than sundown)
Username: Skibum12189
Cleveland
Post Number: 1579
ctmike WAS sellin two. I know for sure he sold one...the other may have been pending...I think he was askin 280 and theyre bnib
Username: Ctmike
Ct.
Post Number: 5059
yep, still have a bnib sundown for sale:-)
A pic is worth 1000 posts!!
Post Number: 9915
How did that come about?
Great amp. Jump on it.
Username: Jtown
Post Number: 309
sundown is better than hifonics, but whatev.
that sundown is a good tho.
Username: Adddisorder
West palm, Florida
Post Number: 5055
damn mike what are you going for the 3000d
Username: Ctmike
Ct.
Post Number: 5061
possibly:-)
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 441
Grab the one from ctmike.
Post Number: 41
ctmike how much ???
Username: Jesse59672
OKLAHOMA
Post Number: 599
ctmike i'm in the middle of returning an amp and if i get my money back i'll more than likely buy yours. but its w/e
Post Number: 42
ya i have two 12" type R's so this Sundown amp would be perfect
Username: Ctmike
Ct.
Post Number: 5065
$270 shipped, bnib with warranty.
Post Number: 44
whats bnib im stupid so..
Post Number: 45
$h1t nvm i no
Post Number: 46
yo ctmike i will prolly get that amp so tell me what the deal is
thx
Username: Ctmike
Ct.
Post Number: 5069
paypal, money order, or check. don't care none.
Post Number: 47
ok i will get back to you tomarrow and let you know whats goin on
Post Number: 48
this amp will be good for two type r's right?
Username: Ctmike
Ct.
Post Number: 5070
yeah, so long as thier dual 4ohm vc. you could give them more power though, but that also depends on your electrical as well.
Post Number: 49
ya they are dual 4s and also
what do you mean by electrical (gotta bare with me, first system)
Username: Ctmike
Ct.
Post Number: 5071
alternator, battery, big 3 upgrades. if running alot of power you'll want these upgraded. depending on the alt. you have now you should be able to run 1000wrms with no problems, but doing the big 3 wouldn't hurt any at all.
Post Number: 50
my car is a nissan altima 1999 and i think it gives 12 volts is that enough to power it all?
Username: Ctmike
Ct.
Post Number: 5072
haha. either look at the alt. or try www.autozone.com, enter your vehicle info, and search for alt.s' and see what the size is.
OKLAHOMA
Post Number: 606
they all usually give 13.5 voltage. but its the higher number amperage that you'll need.
Post Number: 51
its only got 100 amp idk if that good bad or horrible
OKLAHOMA
Post Number: 608
just depends on how old it is. if its not pretty new, then its not giving 100 amps. you MIGHT be okay but if it was me I would buy a new alternator on 1000w rms. it will save you a lot of trouble down the road when your alternator decides to crap out on you. because eventually it will
Username: Ctmike
Ct.
Post Number: 5075
you should be fine with 1000w. i'd still do the big 3 though. cheap and helps alot.
big 3 instructions:
http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
Post Number: 52
ok thank you mike. i will get back to you about the amp tomarrow
thx alot
