Username: Mendonmafia USA
Post Number: 415 Registered: Aug-06
Thursday, August 30, 2007 - 02:31 GMT the rear panel (the panes w/o the subs) is going to be a 3/4inch thick peice of plexi
Username: Van_man Boston South,
MA
Post Number: 2791 Registered: Mar-06
Thursday, August 30, 2007 - 03:01 GMT Nice angles. Is that the port on the bottom? Whats it like 1"? Cool. Are you gonna paint the back sub baffle too?. What you covering it with? Nice.
Username: Cenus Hicksville,
Ohio
Post Number: 3510 Registered: Jan-05
Thursday, August 30, 2007 - 03:05 GMT on the left upper side wtf is up with that baord, is it just from the way it was cut or is it warped really bad?
Username: Crayola0 Future 15 Wanger!!,
Wisconsin
Post Number: 2077 Registered: Jun-06
Thursday, August 30, 2007 - 03:10 GMT blade looks like it could be dull?
Username: Tejcurrent Post Number: 279 Registered: Apr-07
Thursday, August 30, 2007 - 03:12 GMT Looks like burn marks from a dulling saw blade, or it just had the wood jammed against it hard. My blade is getting dull.. Nice looking, but that port is going to give you a problem. It really should be more square shaped. Nice job though!
Post Number: 416 Registered: Aug-06
Thursday, August 30, 2007 - 14:16 GMT the burns are from using a crappy table saw and the blade was getting pinched. I will be painting the entire box black inside and out. The port is 1x36 inches i was very hesitant about doing it like that but it looks pretty sweet i think. But will it sound bad now? Dustin, im not sure what you are tlaking about so i cant answer your question but none of the wood was warped.
Post Number: 417 Registered: Aug-06
Thursday, August 30, 2007 - 14:17 GMT i will have more pics today when i get some paint on the outside.
Username: Th3pwn3r Post Number:...
Post Number: 4537 Registered: Jul-06
Thursday, August 30, 2007 - 14:24 GMT How many SQ inches of port was that designed at?Also...to what frequency?
Username: Insearchofbass Post Number: 6310 Registered: Jun-04
Thursday, August 30, 2007 - 16:36 GMT with a 1 x 36 port im afraid your going to have port noise by what they recommend it should be 4.5 high by 36 (1 to 8 ratio)
Username: Insearchofbass Post Number: 6311 Registered: Jun-04
Thursday, August 30, 2007 - 16:40 GMT but thats ALOT of port area
Username: Insearchofbass Post Number: 6312 Registered: Jun-04
Thursday, August 30, 2007 - 16:47 GMT at this point im not sure how much you can do since your port tune will raise with a taller port
Username: Bestmankind SOUND SPLINTER RL-S ON...
Post Number: 14962 Registered: Oct-05
Thursday, August 30, 2007 - 17:17 GMT nice looking box. it looks like you took sometime to make it just right. mad props.
Ohio
Post Number: 3512 Registered: Jan-05
Thursday, August 30, 2007 - 17:29 GMT i was talking about the second pic, just to the left of the sub cutout, i couldn't tell if it was just burn marks from a dull blade or if the board was warped.
Username: Loc_out Santa Ana,
Ca
Resonant Eng...
Post Number: 1073 Registered: Feb-05
Thursday, August 30, 2007 - 17:49 GMT Looks good mafia lets us know how it sounds.
Post Number: 419 Registered: Aug-06
Thursday, August 30, 2007 - 21:24 GMT yea dustin they are just burn marks. I used to have bad port noise with my old box but i had 2 round ports that equated to 25 sq inches of port area total and tuned to 35.5 hz this new port is 36 sq inches and flared and tunes to about 34 hz Wouldnt just increasing the area make for less noise? The 2nd coat of paint and caluk are drying rite now. i will take some more pics just before i put the plexi in which should be in about 2 or 3 hours
Post Number: 422 Registered: Aug-06
Monday, September 03, 2007 - 01:27 GMT OMG!!! this box is crazy loud and clean sounding hardly any port noise. I will post pics and a video tommrow cuz im about to go out now.
1000 posts!!
Post Number: 9759 Registered: Jun-06
Monday, September 03, 2007 - 01:39 GMT Nice man! Where did you pick up the plexi?
Username: Insearchofbass Post Number: 6361 Registered: Jun-04
Monday, September 03, 2007 - 18:29 GMT glad you dont have alot of port noise but I knew you would have some because your port hieght is too small....glad its loud and you like it too
