Looks like the 400.1 is messed up
Username: Thumpinwith8s
2 RE8s,PG Xenon 400.1, New Numbers ...
Post Number: 870
found out a speaker wire broke loose and may have shorted against the amp. I'm goint to bring it by and have Canaan hook it up at the shop next week, to make sure it isn't the wiring. IF not, he knows a place that we can send it that works on amps. Hopefully it won't be too expensive.
