I am hooking up a sub into my moms 2000 Honda Odessy (mini van) I got everything hooked until i got to the REMOTE wire, i know that all Honda's are mostly the same so if you know where to put the Remote cable post something. Even if you dont have one and are using a STOCK head unit than post, i need alot of options.
if you don't have a remote trigger on the head unit, connect the remote lead from the amp to an ignition line, so the sub/amp turns on when the keys are turned to ACC or IGN.
