Confused on high sub notes????
Username: Djhasanicesoundsystem
Vista, Ca Usa
Post Number: 152
ok when the high bass hits it really doesnt hit hard. is there anything wrong with subs or should i just get some mid-bass speakers or highs for the car
Username: Tejcurrent
Post Number: 305
Get some mids. You really should cross over around 60hz.
Username: Th3pwn3r
Post Number:...
Post Number: 4564
Some cars peak higher than 60hz though.I doubt you're worried about such a high note though i Luv bass.Like Troy said get some midbass speakers.
Vista, Ca Usa
Post Number: 153
cool thanks but what are some good mids in this case and should i get them to fit in my stock spots or should i make some boxes for them and put them next to my subs
SOUND SPLINTER RL-S ON...
Post Number: 14969
get a nice 3 way comps up front.
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 4106
i H8 Bass
Vista, Ca Usa
Post Number: 154
drivingreckless that aint nice haha but ya will that work good enough in this situation? and what are a good brand of these 3 way mids
Username: Jakeyplaysbass
ASU
Post Number: 1957
that depends on what you want to spend man. honestly it goes HU, speakers, amps (alternators and batteries), then subs. until u have a little taste of everything nothing will sound "good".
in your case i would get a good set of 2 ways (if you want to spend under 500 including amp) or 3 ways (over 500). a good 2 way will sound better than a crappy 3 way. but a good 3 way will sound better than an above average *better* 2 way with the right install.
