Uhoh... Starter problem, or alternator?
Username: Cried
Erie, PA US
Post Number: 573
Ok, I was parked at papa johns today, and as I was leaving, and i went to start my car i turned it halfway over and my radar kicked on and my radio and my lights n sh!t, but i turned it over and nothing, turned it over, nothign again, did it about 5 times, nothing, 6th time it started.
do u think its my starter or alternator, or something different, much help would be appreciated, whatever it is, I need to get it fixed, im afraid im gonna be stranded and one time it wont start. Thanks in advanced
Username: Jesse59672
OKLAHOMA
Post Number: 570
have your battery checked first (make sure theres no corrosion), then do a charging system test. if not either of them then i would check your starter.
Username: Cried
Erie, PA US
Post Number: 574
I cleaned the battery and put anti-corrosion spray on it, and its been clean ever since.
Username: Van_man
Boston South, MA
Post Number: 2792
Sounds like starter soloniod is going. Have the starter checked, and check the wirering to it as well.
Username: Tejcurrent
Post Number: 280
I've seen lots of people with aftermarket terminals have the wires come loose a little, I'd check that first if you haven't. If it's not your charging system good luck.
Username: Cried
Erie, PA US
Post Number: 575
thanks, im pretty sure its my starter everything was perfect until today, and i havent messed with anything electrical for at least a month.
Username: Crayola0
Future 15 Wanger!!, Wisconsin
Post Number: 2080
ya check the battery terminals for loose wired cause once i was leaving work and my car wouldnt start and i looked and the terminal was loose and ive neva messed with it before that
Username: Crayola0
Post Number: 2081
what kind of vehicle do u have cause my friends sonoma's starter went out and a couple days later my other friends s10's starter went out
Username: Th3pwn3r
Post Number:...
Post Number: 4496
When people say "turned over" they usually mean the start is turning the flywheel and if it's "turning over" there wouldn't be a problem with the starter.If you're turning the key and just hearing a clicking or nothing at all there is either a problem with the starter or there's a problem with your charging system.Have someone give you a jump and if it starts right away there's something wrong with your charging system but if it still isn't turning over it's probably your starter.
Username: Cried
Erie, PA US
Post Number: 576
it wouldnt crank at all, it clicked a bit on some of the times i turned the key over but other than that it wouldnt even make a noise like it was attempting to crank, so i figured it was the starter. I dont think it was my battery cuz when i turned the key halfway, all my electrical devices turned on no problem, just like normal. I am thinkin its my starter.
Username: Skies
Courtenay, British Colu... Canada
Post Number: 804
If it happens again, just hit(not TOO hard) the starter a few times and then try again. As mentioned above, could be starter brushes, solenoid on starter, or solenoid on the frame.
