Ai÷ for pioneer tsw 2504spl
Username: Paogr
AthensGreece
Post Number: 133
How many cf are good for this sub?
I remember rovin at his 3002 had 3cf, so 2cf for the 10" are enough?
Check my plan and tell me your opinion.
http://www.subwoofertools.com/forum/ported-box.asp?Ew=25&Eh=14&Dia=4&Xmax=8.1&Vd =0.061&NumW=1&Vb=2&Fb=35&Qts=&Vas=&Fs=&CE=0
*this box is for a friend
Username: Th3pwn3r
Post Number:...
Post Number: 4486
I'd probably tune higher for those subs.
Username: Paogr
AthensGreece
Post Number: 134
About box volume???
Is 2cf too much?
Username: Rovin
4 10 Pioneer...
Post Number: 12081
never used that 1 b4 (800wrms right ?) - i usually use a 1.7 on the lower 350wrms model so IMO 2cuft should be cool & ur box plans like good to me .....
Username: Paogr
AthensGreece
Post Number: 135
OK, thank you very much rovin. I'm going to build this box in a few days
