Anonymous | hi I was just looking at a JBL 600.1 and a 1200.1. anyway my question is these are suppose to be mono amps then why do they have 2 channels if they are mono amps aren't they only suppose to have 1 channel? Sorry about the dumb question just new to this stuff. |
Silver Member Username: Jonathan_fGA USA Post Number: 117 Registered: May-04 | The two terminals are just there for easy hookup. It simplifies the install over having to cram the wires on one terminal. It's still a mono amp. |
Anonymous | Ok then how do I connect 2 2ohm DVC kicker CVRs to it? |
Silver Member Username: Jonathan_fGA USA Post Number: 127 Registered: May-04 | Wire the coils in series, then wire each subs' pos. and neg. wire to one terminal of the amp. http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=DVC2x2 Do it for a 2 ohm load. The only difference is that each sub gets it's own terminal instead of sharing one. |
Anonymous | ok cool thanks alot. |
