Building a ALL plexiglass speaker box
Username: Bigmatt1986
Jacksonville, Florida U.S
2x 15' with at least 4 or 5 inch port down the middle
Username: Insearchofbass
Post Number: 6336
big spending when it comes to building one of those
SOUND SPLINTER RL-S ON...
Post Number: 14985
have you worked with plexiglass before?
better take alot of pics. that will come out looking sweet. i might copy you if it looks good. :-)
Im good i just need to know one thing would it make a difference if i made the speakers facing upwards towards the roof
i took wood shop for 4 years there was a kid that i helped make a enclosure for his amps
Username: Denali_on_22s
Im just light up my......
Post Number: 2754
plexiglass is not wood.
i know that i was wondering if it would make a difference if i made it to were the sub woofers faced up
Username: Loudon
Post Number: 1654
depnds on ur car ...
these are my speakers now
Aye so what yall think
Username: Tejcurrent
Post Number: 309
subs up port back.
Post Number: 7
you think i should make it port facing seat?
Username: Mendonmafia
Post Number: 420
i think he said you should put the port facing back. as do i, this will reduce, if any, the port noise. also put the subs facing up.
Post Number: 8
i dont get port noise so ill do it like that when i make my new plexi glass box getting the tools and glass this weekend and building next weekend imma take pics
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12728
what are those??? PA??
Post Number: 9
power Acoustik yes if PA is the short term
A pic is worth 1000 posts!!
Post Number: 9679
Plexi is VERY expensive. This is where I bought my plexi from on my last box.
http://www.professionalplastics.com/cgi-bin/pp.pl?pgm=co_disp&func=displ&strfnbr =3&prrfnbr=100409&sesent=0,0&search_id=82085
Username: Visitor
Middleofnowhere, Minnesota USA
Post Number: 81
also- estreetplexi.com has very good prices, and service
Username: Visitor
Post Number: 82
www.estreetplastics.com.. sorry bout that
Post Number: 10
i was thinking to getting the plexi from like Lowes or The Home Depot but i havnt checked for prices yet
Username: Kpa2727
Post Number: 579
i worked at lowes for almost 2 years thier to damn expensive trust me u will drop nearly 400 there plus they don't have thick stuff.
Post Number: 11
Crap because i hate ordering off the internet. And also i forgot the equation for finding how much product i need after my plans. Just so i dont over order the plexi glass.
Username: Kpa2727
Post Number: 580
to much is never a bad thing to little and u got problems.
Post Number: 9703
Actually if you sit and do the math when you order the plexi you can save yourself the hassles of cutting it yourself. Their cuts are razor perfect and it's all downhill after that. No waste means you're not paying for product you don't use. It truly is that expensive.
Post Number: 12
so what site will cut my measurements for me if i give them my plans and should i use 3/4 or 1" thick plexi or other
Post Number: 13
Also would it sound the same as it would in MDF board?
Post Number: 9706
Use the Professional plastics link above and use the cut to size calculator. Their tolerances are .125" so just round out your box dimensions to that. No splintered edges and clean sharp cuts. You'll see how expensive it is when you input the sizes and get the cost.
For example a 3/4" thick piece cut to 12 1/4 X 36 3/4" is $100.50. Each!
Pricey!!!!!
