Need Help about 2 15" L7
Username: Colton08
Vancleave, Ms US
I'm getting 2 15" L7 and i'm getting a dual vented box and my current amp is a jbl power series bp600.1 i was thinking about getting the 2ohm subs with a boss 2-channel 4000 watt amp.... cause i don't have enough to get anything more expensive then that.... would that work... it have 900x2 @ 2ohm
Username: Jesse59672
OKLAHOMA
Post Number: 566
if your amp is 1 ohm stable then buy 2 dual 4 ohm l7's. then you can wire them in parallel and run 1 ohm. if not then i would just stick with one or buy a bigger amp.
Username: Tejcurrent
Post Number: 269
I would not buy that boss. How much $ do you have to spend?
Username: Colton08
Vancleave, Ms US
so my current amp could run one 15 l7.... what is the main concern with 2ohm and 4ohm subs
Username: Colton08
Vancleave, Ms US
well i'll have 200 after getting the subs
Username: Colton08
Vancleave, Ms US
any ideas??
Username: Colton08
Vancleave, Ms US
kicker KX800.4 work
Username: Rovin
4 10 Pioneer...
Post Number: 12072
personally i wouldnt get that sub to begin with & also stay away from boss .......
Username: Th3pwn3r
Post Number:...
Post Number: 4495
"personally i wouldnt get that sub to begin with & also stay away from boss ......."
I agree completely.Boss products are complete garbage and should never be purchased period.
