has anyone had the same problem as me?? i noticed that when my system is hooked up, the reception on on my stereo for FM goes down and i get very poor quality radio? if so how could i fix this because as soon as i disconnect everything the radio sounds great
details please what's the system consist of? how is it all wired?
well i just have 1 monoblock amp for 2 12"subs and all the door speakers are connected straight to the head unit (Panasonic)all the wiring was done professionally but i recently took the amp out and when i put it back was when i got the problem. the reception is fine at low volume but as soon as i raise the volume, the static comes in pretty bad, the amp is powered by 8gauge power wiring from a distributor that has an input of 4gauge wire, ground wire is 8 gauge also
re-check your amp wiring. this sounds like a bad ground. also make sure your signal lines (RCA) are separated from teh power cables. having them side by side can introduce noise.
This really just sounds like a wiring faux pas somewhere.
