i know some ppl on here do that, like i remember killa was doin it in his caddy, but my friend has a 94 lincoln continental. anyone know how hard it is to do this or if its even possible?
Like Twiztid said above,get a line out converter and all you have to do is tap into your rear speaker wires at the head unit and then run your RCAs from there.It's best to place it with the head unit in case you ever upgrade to a newer one because then you'd have your RCAs already run where you need them to be.
