Battery Q:
Username: Kaprese
Walstonburg, NC USA
Post Number: 458
I was wondering if you didn't have a upgraded alternator could you run a small battery like a lawn mower battery in the trunk of the car and hook it up to the amp? wouldn't this decrease the load on the alternator since the battery is small and doesn't need alot of voltage
Username: Santa_fe
Post Number: 71
yea but when that battery runs out of charge its gunna require that ur alt re-charge that as well...just like a really big capacitor kinda
Username: Kaprese
Walstonburg, NC USA
Post Number: 459
but then wouldn't I need a isolator so the front battery want die on me
Username: Kaprese
Walstonburg, NC USA
Post Number: 460
but would you be able to do this week a stock alt for a SATURN SL2 I think it's about 90amps, but I am nervous because my brother had the same battery in his trunk (he drives a Chevy Lumina) and he killed his front battery so.....
Username: Santa_fe
Post Number: 74
well, this is where this get risky.....what amp are u gunna run off this second battery, an isolater, so what ur saying is toss a switch between ur main batt in front and the second one in back???? In the end u still have to rechage that batt in the back....and on a small mower batt im not sure how long u play ur subs, once again depending on ur amp/current draw
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1058
why not just buy a HO alternator??
Username: Santa_fe
Post Number: 75
lolz he does have a point...do ya really need that batt in the back??? What are running??..if ya juts want the batt in back relocate the main batt to the back = )
Username: Kaprese
Walstonburg, NC USA
Post Number: 462
Where can I find a HO Alternator ? how much ? and were can I find one for a 1997 Saturn SL2 ?
if you can find me a link it would greatly be appreciated.
Username: Kaprese
Walstonburg, NC USA
Post Number: 463
I am running a Earthquake T1000w/2 amp about 600-700rms and a Memphis PR15D4 sub
Username: Santa_fe
Post Number: 76
so two earth quake subs?? or one but on stock u should be okay i wouldnet run over 1500 on stock
Username: Kaprese
Walstonburg, NC USA
Post Number: 465
No the amp is the Eartquake but running only 1 sub the memphis
Username: Nd4spd18
Southeast PA
Post Number: 3213
Batteries do NOT supply power they store it. ALternator is the power source, so get an HO alt.
A pic is worth 1000 posts!!
Post Number: 9667
***Insert Muddy's sig***
