Download Procedure for Pansat 2700A
Username: Heyhowru2004
Post Number: 46
Can someone help me with the Download Procedure for Pansat 2700A ? Is this the correct steps? Should the reciever be turned OFF in second step?
Thanks
1.Connect RS 232 Null Modem(#2,3 crossed) cable between the receiver and PC.
2.Turn the receiver power OFF. (from the back panel)
3 Open the GTRom Loader V3.35 (Pansat 2700A).
4.Click BIN FILE and select the Bin File to be downloaded.
5.Turn the receiver power ON and as soon as you see the 1st green light click Downlaod.
6.Do not interrupt the receiver power while downloading.
7.Press OK after Download Complete!! appear on the PC screen.
8.Receiver will reboot itself.
9.Go to the Parental Control Menu
10.Select the second PIN and enter 0000.
11.Select Set default key
Username: Asharfi
Post Number: 700
Yep, that's the correct procedure!
Username: Lklives
Post Number: 11512
NO, not any more...it was good until March 2007...its all good, EXCEPT now U must use loader 27.02 for newer bins since bin #200...and U must have done a B75 Boot upgrade (only once) too since March 2007...otherwise the procedure above is correct...
Username: Asharfi
Post Number: 713
Oh ... Thanks for the update .... Joe ... there you go
