WHERE DID WWW. DSSCANADA.,COM GO??????
Username: Toyotaman
Noble, IL Usa
If anyone could tell me what happened to dsscanada. I keep trying to go their site but telss me it no longer exsists Was just there 3 days ago. Can this be possible Or do they realize that the will never be a hack for the p4 card so they decided to close down before everyone demand a refund from them that just bought equipment and support, Also you cant get to www.support.cx either it wont let you find the web site
try www,dsscanada.ca i think this is the same sie......jmill
Username: Jmill1948
Chester, Va Usa
www.dsscanada.ca
Username: Toyotaman
Noble, IL Usa
it isnt the same web site but thanks
Dish Cards
P4 P5 Dish Cards and Programmers
Do anyone know what is happening with the hack for the p4 and p5 cards
NO-SAT-TV
THEY MAY HAVE GOTTEN BUSTED AND SHUT DOWN.YOU CAN TRY OTHER SITES LIKE DSSCANADA.CA THEY OFFER SAME STUFF AND INFO. STAY IN TOUCH
