New member Username: Mikegault7Post Number: 2 Registered: Aug-07 | I have a 4dr colorado and took out the back seat and have 2 of the 9510-44's (going for 1 ohm wiring)(750w rms/ 1500w max each)and was wondering what amp would be good? I am planning for 2 spl boxes with a single seat in the middle, a lil bigger than spec to compensate for the polyfill to help with the low lows. I know car audio but Im far from an expert so I would like to know how I can make this the best that it can be. deck: alpine cda=7998 mtx 8000 components in front mtx coaxials in back doors for now alpine amp on highs thanks in advance mike G |
Gold Member Username: InsearchofbassPost Number: 6297 Registered: Jun-04 | polyfill makes the box appear larger to the sub as long as you dont over stuff it |
New member Username: Mikegault7Post Number: 5 Registered: Aug-07 | so I should use it and compensate by making the box slightly larger? how do you overstuff a box? this will be my first experience with polyfill... what is a good place to get polyfill? thanks for the info |
Gold Member Username: InsearchofbassPost Number: 6305 Registered: Jun-04 | Heres an in depth study......you can buy it at walmart or you can mke the box the right size but I feel polyfill helps the sub sound better also http://web.archive.org/web/20020808224043/integra.cyberglobe.net/caraudio/resour ces/fiberfill/ |
