Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 4059 Registered: Apr-06 | this setup did 135.8 @ 51hz on a TL at dash sealed up.... its pauls royal red pyramid sub... this sub slams harder then some systems around here.. wired at 4 ohm the sub is only gettin 1000 watts |
Gold Member Username: JkidderIA, DP RD Post Number: 1782 Registered: Nov-05 | lol outdid wolfman |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 4065 Registered: Apr-06 | with 1 10" |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12049 Registered: Jul-05 | now thats a big azz port ! .... |
Silver Member Username: ImnothereimjustvisitingPost Number: 113 Registered: Aug-07 | lmao thats cool |
Gold Member Username: JkidderIA, DP RD Post Number: 1783 Registered: Nov-05 | i wanna see it burped at 1 ohm |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 1643 Registered: Jun-06 | I wanna see a vid. |
Bronze Member Username: Patrick_ortizSan antonio, Tx Usa Post Number: 33 Registered: Aug-07 | wow thats a giant box for that little thing, pretty cool, check out my solo x thread |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 4066 Registered: Apr-06 | "I wanna see a vid." il try to find some batteries and make one tommorrow |
Gold Member Username: MixmastaspigCanada, Canada Canada Post Number: 1060 Registered: Sep-05 | x 2 on the video dude! |
Gold Member Username: Extrmndor3Post Number: 6661 Registered: Feb-06 | drivin ill rip your head off and shyt down your neck...........im gonna get medieval on your fu-cking azz.... and finally....... your an inspiration for birth control |
Silver Member Username: Thumpinwith8s2 RE8s,PG Xenon 400.1, New Numbers ... Post Number: 822 Registered: Jun-07 | ok, so it outdid me , with 1000 watts! Im doing only .3db less with 425watt, less than 1/2 |
Gold Member Username: JohnfiacA-ToWn, 9515 thumpin... What u bumpin? Post Number: 3468 Registered: Mar-06 | thats a 3rd baffle to make your 15" sub cutout fit wwith the 10 right? id hate to see al that wood being wasted for a test on a POS sub lol... "out did wolfman" its also 4x the power lol, wolf i thought ur using the 500watt jensen? it only does 250 rms i thought.... |
Silver Member Username: Thumpinwith8s2 RE8s,PG Xenon 400.1, New Numbers ... Post Number: 825 Registered: Jun-07 | not sure what the jensen did, but I've been using a PG Xenon 400.1 with 425 watts for a good while now, bought it from ADDDisorder much better amp, no overheating or cutting out. also much louder and cleaner bass |
Gold Member Username: Adam_sPost Number: 1879 Registered: Aug-04 | That box is huge for that sub and no offense wolfman but Daves was all sealed up and I believe yours was outlaw. |
Bronze Member Username: Talon01York, Pa Usa Post Number: 50 Registered: Jun-07 | thats good .....we also did 135.2 db with an entry level american bass 10 on the ac meter restricted port (with 14 square inch port) and 300 watts rms it would probably do 136. something to 137 db unrestricted http://www.youtube.com/watch?v=-tVshJrV4hY |
Gold Member Username: InsearchofbassPost Number: 6264 Registered: Jun-04 | ^^^that post was me our was sealed up at the dash.....and listen to the major port volocity.....good work driving |
Silver Member Username: Philly306North carolina Post Number: 313 Registered: Apr-07 | pyramid ftmfw |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 4067 Registered: Apr-06 | wolfman... sealed up > outlaw 2 8s(cone area) > 1 10" (cone area) now stop b!tching i didnt make this thread to insult you anyways so what if its a waste of wood killa i rather have some bump then no bump... g/j scott i just did a direct drop in not really caring about metering this was only for fun... "pyramid ftmfw"!!!!!!!!!!!!! damn str8t |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 4068 Registered: Apr-06 | "its also 4x the power" 1000 / 4 = 400???? killa go back to school you stupid c\/nt |
Gold Member Username: Denali_on_22sIm just light up my...... Post Number: 2751 Registered: Feb-06 | it's also a pyramid sub your jackass... driving>wolfman |
