Brahma question
Username: Martice
Hello all. I am looking at the Brahma 10 for use in my Toyota Corolla sedan. I am looking for a small cabinet like 13" x 13" maybe. Anyway, I am not looking for earth shaking bass but would like to have full range sound inside the car.
I noticed on Acoustic-Visions website, the information they give the following information about the Brahma 10
"Sealed Car 0.25 to 0.85 cubic foot
Vented Car 0.75 to 1.25 cubic feet tuned to 35 Hz"
I don't know how to convert cubic feet to inches and would like a little help in this area so that I can get a picture of how big a cabinet 0.25 to 0.85 cf is.
Thanks
Username: Sploosh56
Post Number: 40
Just use this formula
Length" x Width" x Hidth" / 1728
Make sure that these are internal measurments of your box.
Username: Jonathan_f
GA USA
Post Number: 37
Yeah. If you use 13x13x13 OD, with 1" MDF (highly recommended), subtract two inches. It'll really be 11x11x11 ID, which is .78 cu ft (rounded off). It will work. If you want to make the box seem bigger, you could use polyfill.
