Silver Member Username: Cartier1Post Number: 860 Registered: Feb-07 | some site claim that 294 for pansat 2500 is rolling just it takes little time. |
Gold Member Username: NydasPost Number: 3429 Registered: Jun-06 | With 294T on a clone, the autoroll works, whether it is off or on. The first number of Key 00 and key 01 is changed. I have posted a table in another thread, you can use if you don't want to bother getting into the internet. The technique works. If you understand binary, you have to XOR the first number(s) with 43H. Another way of learning it is to invert bits 6,1,and 0. Or use the the table I have posted in th ekey morphing htread. |
Bronze Member Username: LauradPost Number: 13 Registered: Aug-07 | I tried to load 294 on my 2500A, the uploader is not like my old one. I have instructions I received yesterday. How do I get te GTRom STB update |
Silver Member Username: Cartier1Post Number: 861 Registered: Feb-07 | go to future-fta you will find what you are looking for . |
Gold Member Username: NydasPost Number: 3432 Registered: Jun-06 | Use Bl updater 1.4 |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 109 Registered: Mar-07 | nice to see you back Nalin |
Bronze Member Username: KazanrovPost Number: 16 Registered: Jan-07 | if somebody can help me please i have viewsat lite and put it the new bin but i can't see it in my room in the house of my friend I can see nothing I don't know what is the problem b/c with the same sattelite i saw the clone(2500 quantum)pleaase3 i need your help. |
Silver Member Username: Cartier1Post Number: 874 Registered: Feb-07 | more information needed we dont live with you so we dont know what is your configuration . dishsss, ecttttttt |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2893 Registered: Nov-06 | ??? bump ??? |
New member Username: DodersPost Number: 1 Registered: Jun-07 | explain please the method for getting the first numbers in [english] my autoroll is doing the same thing first set of numbers comes up wrong. |
Gold Member Username: NydasPost Number: 3485 Registered: Jun-06 | For the 294T BIN after the autoroll, Since 17th August, use the following table. Apply it to the first number of key 00 and key 01. Of course, you can always use keys posted on the internet or in this forum, but if you do not want to or can't get to the keys this is a useful way of getting going. 1st digit.....2nd digit 0 = 4 ........ 0 = 3 1 = 5 ........ 1 = 2 2 = 6 ........ 2 = 1 3 = 7 ........ 3 = 0 4 = 0 ........ 4 = 7 5 = 1 ........ 5 = 6 6 = 2 ........ 6 = 5 7 = 3 ........ 7 = 4 8 = C ....... 8 = B 9 = D ....... 9 = A A = E ....... A = 9 B = F ........ B = 8 C = 8 ....... C = F D = 9 ....... D = E E = A ....... E = D F = B ....... F = C |
Bronze Member Username: LauradPost Number: 14 Registered: Aug-07 | What do I do if the 00 0101 for keys is not working. I have 2500a Pansat, should I be in Nagvision 1 or 2, can't post manually don't know how to get alphabets in.. Help |
Gold Member Username: NydasPost Number: 3531 Registered: Jun-06 | With BIN 294, when you first load it, you will have date set to 01/01/2006. Go to User settings and change the date, time and time zone. To enter keys in Pansat 2500A and clones, you have to scan at least one Satellite. Only then you will be able to do Menu/Parental control/second Pin: 0000 Always have autoroll off when you enter new keys. Go to Nagra 2. Nagra 1 is NOT used any more. Provider ID for DN is 0101, for BEV it is 0901 and for Globecast it is C101 You should be able to enter all 16 numbers of 2 digits each for key 00 and similar for Key 01. BIN 294 autorolls but the first number in key 00 and key 01 is wrong. So if you have allowed to autoroll, you will probably need to change only the first number. |
Bronze Member Username: Tigger_woodsPost Number: 58 Registered: Jun-07 | http://www.dailytech.com/Survey+Less+Than+Half+of+all+Published+Scientists+Endor se+Global+Warming+Theory/article8641.htm |
Bronze Member Username: LauradPost Number: 15 Registered: Aug-07 | I finnally got it when it comes to entering the new keys, now I keep getting no signal or bad channel, what should I do next, I did a sat scan Thanks for the help. A Light Bulb is coming on |
Gold Member Username: NydasPost Number: 3543 Registered: Jun-06 | Have the current DN keys handy. BEV is not working now. You must have scanned DN by now. 1. goto Menu/parental control/second pin. Enter 0000. 2. Set autoroll and atuto tp off. Exit exit. 3. Check that you have correct date, time and time zone. 4. switch off at back - wait 30 seconds and switch on. 5. let it roll. It will probably go to 300% or 400% or something like that. 6. When it stops this insane count up, it will attempt to start again. 6. At that point goto Menu/parental control/second pin. Enter 0000. 7. Go to nagravision 2. 8. Currently only DN is working. 9. Select provider ID 0101. 10 Go down. enter 1st number in 00 - if you have thenumber use it or change it from table above and then use it. You iwll find the rest of the key numbers are the same as you have in you list. 11. Go to key 01. do the same. 12. SAVE. exit, exit exit exit. Watch TV. Good luck. |
