Silver Member Username: Thumpinwith8s2 RE8s,PG Xenon 400.1, New Numbers ... Post Number: 817 Registered: Jun-07 | both the new HU and Coax's http://www.sonicelectronix.com/item_9007_Panasonic+MXE+CQ-C7205U.html http://www.etronics.com/product.asp?State=LA&showship=ok&stk_code=phorsd65 |
Silver Member Username: Thumpinwith8s2 RE8s,PG Xenon 400.1, New Numbers ... Post Number: 818 Registered: Jun-07 | oops on the coax's this one should work http://www.etronics.com/product.asp?stk_code=phorsd65&store=BH&catid=358 |
Silver Member Username: Thumpinwith8s2 RE8s,PG Xenon 400.1, New Numbers ... Post Number: 819 Registered: Jun-07 | hell, cant get the etronics link to work, anyway, its a pair of PG 6.5 RSD's, can get them for $50 |
Gold Member Username: JkidderIA, DP RD Post Number: 1768 Registered: Nov-05 | doesntwork |
Gold Member Username: Tremor1127Fi Post Number: 2217 Registered: Aug-06 | get a component set... |
Silver Member Username: Thumpinwith8s2 RE8s,PG Xenon 400.1, New Numbers ... Post Number: 820 Registered: Jun-07 | well, its a pair of PG RSD's |
