Massive RS 100 or Audiobahn A8002t for a pair of MAW 12s?
Username: •cam•
Post Number: 610
Posted this in the amp section but you know.
If you had to choose between those two amps which would it be? I can get the RS 100 locally for $200 CDN and the a8002t is probably gonna be about the same maybe a little less from somewhere else.
Username: •cam•
Post Number: 612
cmon everyone on this forum has an opinion
Username: Cenus
Hicksville, Ohio
Post Number: 3481
are those your only choices? not really a fan of either brand but if i had to choose i'd go with the massive.
Username: •cam•
Post Number: 613
yeah I know what you mean. if I can I'm gonna get a NINe.1 (it'll match my NINe.4 and they're on for $275). if not I'll probably go with one of those. 1 for the massive then. thanks man.
Username: Jkidder
IA, DP RD
Post Number: 1737
audiobahn
