Big three done, soemthign weird happend.....
Username: Killer44
Ontario Canada
Post Number: 936
so i did my big three tn and now when i play my music its louder at lower volumes then it was before, like at 18 or 20 its jsut as loud at it used to be at 28or30 before i did the big 3....does this usually happen when u do ur big 3...def not complaining cuz this mean my system will now be louder, this is still with stock alt by the way, running a 1750.1.....thanks...
Username: Boomtank
Rochester, NY USA
Post Number: 348
yeah your big 3 is going to allow your charging system to run smoother and allow more current to run to the amp. This will cause your amp to run at a higher voltage and therefor put out a more power. This is why your system is louder. The reason it sounds the same at higher volumes is most likely because the amout of power increase from the big three is not noticable with the amount of power your running. like 50 watts more may sound much louder at lower volumes but when you have 1700 watts running through subs your not gonna notice 50 watts by ear.
