Newly acquired Samsung
Username: Tigerfan4me
Califonia US
My girlfriends dad is giving me their old 46 inch Samsung DLP. the catch? everytime a new lamp is put in it frys it. what could be causing this. i'd like to fix it myself
Username: Omegadealer
its your ballast dude...call samsung or go to samsungparts DOT com and get it replaced.
Califonia US
thanks. that worked perfectly
Username: Shamrez
Try fixyourdlp.com. might be a better bet for you.
Its a full guide to fix your lamp along with the pictures.
Good luck!
Username: Ovadoggvo
Post Number: 54
Samsung's are usually fitted with a Philips 120W e23 or e22 1.0 UHP Lamp. If you're buying a cheap and generic UHP lamp from eBay or somewhere like that, and it is NOT a 1.0mm arc, then that explains it.
IF you are buying the proper lamp and they continue the fail, you've got a weird short in your ballast. Change it. If you've got the older 100W ballast, opt for the 120W ballast and get the new e22 lamp with the adapter. Those small philips lamps are much more reliable than the older e23 Big lamps.
Good luck!
