New member Username: SalimoufPost Number: 1 Registered: Aug-07 | hello , my name is salimouf. ok i have this friend that has the same reciever that i have (pansat 2700a) the problem is his key code (dishnetwork) stays on for 3 months and then (as he told me) he takes it to a man that does it for him and it stays for 3 months more!! a good info is that both our recievers don't have a card enterance!!!! the problem is i have to change my key code 2 times per day!!! , i think it autorolls 2 or 3 times and then stops!! please please tell me what should i do and what should i buy precisly to make my reciever work the same way as my friend's. please provide me with full explination!! another question would be: is it right to? Autoroll: Dishnet off globecast off bev off key code on or should i put all of them on?? and why yes or no? but please help me and don't ignore my question, cuz i've been looking for a good explination for about a month now and thank you for the wonderful information i find on this website! |
Silver Member Username: RunnerguyPluto Post Number: 530 Registered: Sep-06 | When I take to much Viagra my keycode stays on fo 3 months too!!! |
Silver Member Username: Flatulant_kittyPost Number: 286 Registered: Jul-06 | If you have an erection lasting longer than four hours............. Chop it off!!!! |
Silver Member Username: RunnerguyPluto Post Number: 531 Registered: Sep-06 | http://youtube.com/watch?v=H6pq2Ud5H_s |
New member Username: SalimoufPost Number: 2 Registered: Aug-07 | please , one of the admins answer , cuz it's kind of an emergency. plus, whoever wants to post things about Viagra go anywhere else , this is a satellite forum!! please please some one answer me and help please |
Gold Member Username: Hawaiian_timeKanaka freak... Post Number: 1309 Registered: Apr-06 | You need the latest file, 208 for your 2700. It will autoroll. Look for the thread here about 2700s and bin 208. |
Bronze Member Username: Silver1123Mexico, DF Mexico Post Number: 73 Registered: Jul-07 | Salim: Dish Network sends what is called Electonic Counter Measures, in simple terms, software code in the satellite signal that alters autoroll functions. You need to install a fix for your autoroll or keep entering keys manually, since the software in your reciever is no longer useful. Go to As Hawaiian says, download the latest fix for your 2700. You need also to download the uploader, also found in the same site. You will need a cable to connect your computer to your reciever. Run the uploader and follow directcions. Keep in mind that when you download, the files are compressed, you need to decompress them with Winzip. Check here to find the cable you need. You can find it in any radio shack. https://www.ecoustics.com/electronics/forum/home-video/380834.html And get used to spam, even this is a satellite forum, many people use it for spam good luck |
Platinum Member Username: LklivesPost Number: 11262 Registered: Jan-06 | nice simple clear factual informative post juan..good job! |
New member Username: SalimoufPost Number: 3 Registered: Aug-07 | thank you juan you've been great help |
