This is for the ariza 700 receiver only this will not be same steps for other boxes.
For new working key codes always have a good simple to use key grabber that has working keys. [link removed] Is a great satellite dish key grabber that always has working keys for the times when fta websites are busy or you just need them quick.
Ariza 700:
Code: 1. Press Menu 2. Scroll Down to Parental Control, Press Enter 3. Press "i" key on remote, then enter pin number "2004" 4. Scroll down to Set Default Key, Press Enter 5. Scroll up to Nagravision, Press Enter 6. Press VOL Right twice, you will see Dish Network 7. Press CH Down once, then VOL Right Twice, you will now see Nagravision 2 displayed top left You are now at the key 00, Press CH Down once so you can edit the Key Data 8. Enter your new keys (write down the old ones to be safe) 9. Press Ok to store, then repeat with key 01 10. Press exit until you get back to tv, all channels will be available
guys, after installing new bin for ariza 700, i did factory reset and did power scan,keeping network-on and data/fta to off position. i am not getting channel names at all, all i can see is Tv 2343, names but infact these channel have their names. can anyone suggest what can be the problem.
