SIGNAL BOOSTER
Username: Guanajuatos_best
Post Number: 55
DO SIGNAL BOOSTERS REALLY WORK???
Username: Jbarnes
Staten island, Newyork Usa
can you tell me why the keys are only lasting 5 min?
Username: 1tina_chick
Post Number: 98
I got one, tested it, then took it back the next day. It made no diff. - it was passive not powered
Username: Randyz
Post Number: 11
The only use they have is when the cable run is over 100 feet and it will only pick up signal a little, it does not do a thing for quality.
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 2747
I have tested and used the rca 20db inline amp and yes they give you about a 10% increase in strength and quality.Make sure u install them between the lnb and switch,not before or you'll blown or shorten your switch life expectancy.
You should not need them if your dish is aimed correctly. but for long cable runs or cheap coax,use them by all means.
Username: Tapeman
New York City in-HD, NY
Post Number: 1260
In-line signal booster is mainly for analog signals
Waste of money
Even for digital cable is becoming old tech
Use RG-6 double shield or quad shield with snap and seal connectors for up to 175 feet yo'll be fine, take my word.
