Which of these speakers should I get? for the front I have 2 4x6 rockford FRC4246 speakers and im looking to get 2 6x9's for the back, and Ive narrowed it down to these
JBL P953 # Power Handling Peak: 330 Watts # Power Handling RMS: 110 Watts # Frequency Response: 35Hz - 23kHz # Sensitivity: 90dB
or
INFINITY KAPPA 693.5i # Power Handling, RMS: 110 Watts # Power Handling, Peak: 330 Watts # Frequency Response (dB): 35Hz - 22kHz # Sensitivity: 90dB
They are run off of the ClarionDXZ945 head unit Oh, and what amp should I get for them? Or if you have any other suggestions, Thanks
Kappas, but personally, I'd spend the money and upgrade the front to a 5.25 or 6.5 component system and forget rear speakers. The Fosgate 4x6's can't take the power that the Kappas can, and you will kill your front soundstage if you amp the Kappas, on top of that, 4x6's aren't spectacular, 4x6 plates if anything, such as the Infinity's. 6x9's are better, but any oval speaker is not the best for sound quality. I'd do components then a 2 channel amp on those matched to their RMS power rating. Just my .02
