New member Username: Peder25
Post Number: 4 Registered: Aug-07
Posted on What is the best 2000 wrms amp for under $400. It needs to be 1ohm stamble, and be aable to run around 1000 wrms at 2ohms. thanks |
Bronze Member Username: Press1
Yuba City,
CA
Post Number: 89 Registered: Nov-04
Posted on so, do you want a 2000w rms amp that is 1 ohm stable under $400 or a 1000w rms amp that is 2 ohm stable? I'm confused. What are you powering with it? |
Gold Member Username: Naledge503
Http://com4.runboard.c...
Post Number: 1600 Registered: Jun-06
Posted on He's trying to find and amp that will put out 2000rms at 1 ohm and at least 1000 at 4 ohm. You should be able to find an Orion 2500D for $350-$400 |
Gold Member Username: Juliob
Santo DomingoDominican Re...
Post Number: 4861 Registered: Dec-05
Posted on soundstream PCA2000d. Jesse D, man that PA amp is doing the work thanks man. Sorry davis for posting this comment. |
Post Number: 1608 Registered: Jun-06
Posted on |
Post Number: 5 Registered: Aug-07
Posted on what do yall think about the hifonics 2006d? |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 1237 Registered: Mar-06
Posted on Not sure. I have seen alot more Hifonics amps dead this year though. Kevin |
Bronze Member Username: Bumpin_buick
Appleton,
Wisconsin
Post Number: 28 Registered: Apr-07
Posted on orion 2500d i have a few and they kick the crap out of the rest for that price range |
Silver Member Username: Theweasel
2 12 FI SSD,
Colorado
U.S. of A
Post Number: 993 Registered: Mar-06
Posted on X2 on the soundstream. i've got one and i love it |
Post Number: 4868 Registered: Dec-05
Posted on ^^^see, there's one example. |
