Bronze Member Username: Dj_excitePost Number: 84 Registered: May-04 | there used to be a list on here that stated good/bad/and in the middle companies for speakers amps and wat not, where did that go?......yes i tried searching |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 478 Registered: Mar-07 | https://www.ecoustics.com/electronics/products/articles/329117.html |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 9488 Registered: Jun-06 | Good link.![]() |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 486 Registered: Mar-07 | yup |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 487 Registered: Mar-07 | i have it bookmarked |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 5883 Registered: Jul-06 | could use some refining with the newer brands out now..... |
Bronze Member Username: Dj_excitePost Number: 86 Registered: May-04 | yea thats why i asked hoping that the newer brands are on it now. but hey its still great. thanks a bunch |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12025 Registered: Jul-05 | debatable ,but its better than nothing if ur a newb .......![]() |
Gold Member Username: JkidderIA, DP RD Post Number: 1721 Registered: Nov-05 | exactly^^ tons of it is debatable |
