4thewinner Unregistered guest | Go here to check if domane is safe. http://www.betterwhois.com./ If its daves it'll tell you |
Crazy PPL Unregistered guest | How the Hell do you figure a whois search will tell you if dave owns a site??? It will give you the srver domain & such, but it will not say "OH NO Dave Site" that is just ridiculous!! |
4thewinner Unregistered guest | Just learn to read. |
Crazy PPL Unregistered guest | No you need to learn what you are doing!!! |
