New member Username: CrasslogicPost Number: 8 Registered: Dec-06 | Greets all. How would go about wiring 3 DVC woofers to 2 mono block amps for even power distribution? I'd come up with this; suppose we call the sets of pos and neg terminals on a dvc sub "set 1" and "set 2". Could I bridge "set 1" on all three subs to one amp (in other words, run the positive and negative lines out the amp and twist them together, then screw them down to their respective terminals) and as such, run "set 2" on all three to the other amp? I'm used to just svc so i'm not sure what to do. Plus, I can't find a woofer wiring guide online that covers the use of two amps. There has to be a way to wire 3 dvc's to 2 mono amps though. But I don't want to cross any phases and blow sh*t up ya know ![]() Thanks for your info all. Happy boomin' --Q |
Gold Member Username: 420alldaylongPost Number: 2506 Registered: Sep-06 | What coils are the subs? |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 1610 Registered: Jun-06 | here you silly goose... https://www.ecoustics.com/electronics/forum/car-audio/381591.html |
