Which speakers should I buy????
I'm looking to buy a speaker system in the $700 and below price range. I want one that is great for music and movies. I'm looking at the ones below right now. Are any of them not so or do you know if they are very good??????? Right now I'm leaning towards one of the klipsch models. Also do you know of any other good speaker systems???
atlantic technology system t70
klipsch synergy system 6
klipsch quintet
HTD level 3
Paradigm Cinema 70 system
Polk RM-6700
B&W 300 Series
timn8ter
I'm pretty impressed with the Atlantic Technology systems. The cone of the mid-ranges are less suseptible to distortions than many others in this price range. You'll find, after time, that the most difficult part of the audio spectrum to duplicate is the mid-range. This is important not only in music but in HT as you would expect to hear the voices as realistically as possible. A $1000 system isn't likely to astound you compared to more expensive systems but this one is darned good!
Dont forget Energy Take 5.2's. They are a great deal and sound out of this world for their size.
