half of my channels are breaking up pretty bad. espn,discovery channel, spike tv and others. Other channels work great, just like normal. Is it the cable connection going to the back of the box or is it the dish.
U can change your own cables without asking here...we have NO crystal ball here...it could be
weather bad cable or connections trees or something in your "clear line of sight" from the dish U need a new scan poor dish alignment bad switch, if using one incorrect receiver antenna settings
