Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 170 Registered: Jul-07 | I love the Quads but they have less bass than my Rogers L3/5A. Still I put the HsU power sub woofer VTF2 back with the Rogers because it is HUGE, but fits in my "vinyl" room. So the wifes living room has the Quads alone. Looking at a sub to go with them. Size and look being a factor or I would simply get another HsU. Looking at the VTF1 in maple. http://www.hsuresearch.com/products/vtf-1.html OK, I promise to post some pics today. Almost as big as the ugly old VTF2 but looks much better in wood. We don't need or want much bass, as this is not home theater, just 2 channel, and it is an apt. So I started researching small compact subs but have not learned much except a few recommended brand names. Veladyne has been mentioned here and gets good reviews. Has compact models. I see on AudiogoN Monitor Audio 360. There are a lot of subs there and on ebay. The popularity of Home Theater seems to have given speaker makers a big boost. For example, on ebay some cheapies: Psb Alpha Sub Zero i; B&W ASW 300 Subwoofer Maple; Monitor Audio RADIUS 360; Not a big investment so I would be willing to give any of them a try. Ideas? |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 171 Registered: Jul-07 | Just looked at ebay again and see the B&W and Monitor have only 4 hrs left. Oh well, plenty passing by. The truth is I am very tempted to stick with what I know, HsU. |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 172 Registered: Jul-07 | Does front speaker style transmit more into the room and less to other rooms than downfacing speaker? I would guess it is the same because it is vibration from the box, right? I put my HsU up on 4" blue foam then 4" patio block. I think it helps keep sound in the room but am not sure. |
Gold Member Username: NuckPost Number: 8331 Registered: Dec-04 | KC, when the sub is integrated properly, the configuration really does not matter. The firing position of the sub might make proper integration of the unit easier, but that is room dependant. Your requirements, the rolloff, and rollin of the thing will decide for your ears. With either Beethoven or Roll over Beethoven. |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 173 Registered: Jul-07 | "...Beethoven or Roll over Beethoven..." I like that. Right now I am playing Sultans of Swing LOUD on the Sultans of Swing. The mid base on the Quad is nice at that level but disappears on the quieter music. Any thoughts on these cheap units, say Monitor http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D230160190803&ssPageNam e=STRK:MEWA:IT&ih=013 Giving up quality to get a smaller size? |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 174 Registered: Jul-07 | Ebay is wild. I had never looked at it before a month ago. That Monitor 360 sub was won by $10 with 6 seconds to go! But that same thing happened to me already several times. I missed a bunch of deals on AudiogoN too. Most recently a pair of Quad12L went as soon as they went online. I watched my nephew sell a Toyota Pickup in Seattle on Craigslist in 4 minutes! I could not believe it. |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 175 Registered: Jul-07 | "...Right now I am playing Sultans of Swing LOUD on the Sultans of Swing..." Jeez! That was w/o alcohol too. Now playing Money for Nothin" LOUD on the Quad11L. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 5240 Registered: Feb-05 | Last I heard Quad makes a great sub.... |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 177 Registered: Jul-07 | I am sure they are good. There is a beauty on sale now in bird's eye maple but it is even bigger than my old Hsu. Here is one like I have now: I see Quad Lite model is somewhat smaller but is not exactly small at 75 pounds. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 5241 Registered: Feb-05 | I had an Era that was quite small and weighed 70 lbs. Small and dense. |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 2068 Registered: May-05 | I don't know your budget nor do I know the specs and sizes, but a few names to look into are - ERA REL Totem Martin Logan I haven't heard Quad subs. Linn makes a very small and decor friendly sub - Komponent sub. I haven't heard it nor know how much it costs, but you may want to research it. If you've got some cash and space, Naim makes a killer sub. Its about $3K though. |
Gold Member Username: NuckPost Number: 8338 Registered: Dec-04 | For 3k I might consider the JLaudio 13" unit. |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 186 Registered: Jul-07 | Thanks for the ideas, guys. I guess I was checking if my first idea was good.I am pretty sure I will go for the Hsu mentioned at the top. Can't go wrong at the price! The expensive ones don't compute for me because for that kind of money I would buy some speakers that don't need a sub. |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 192 Registered: Jul-07 | I made the order: It is small and black to match the monitors. That will keep her happy. |
Gold Member Username: NuckPost Number: 8354 Registered: Dec-04 | That one looks promising, Kevin. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 5254 Registered: Feb-05 | That's a very good litle sub Kevin. One of the higher end Velo's. |
Gold Member Username: NuckPost Number: 8355 Registered: Dec-04 | Art, you and Frank have commented on the lower Velo's being not so hot. Does this constitute a better quality of sub for a tighter(and higher volume) unit for a stereo? Would you consider this Velo a step closer to a rel or such? More music? |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 200 Registered: Jul-07 | I will let you know when it gets here! Truthfully, if it were for any other room than the living room I would have gone with another one, maybe the Hsu in wood or the Quad. I have no conflict with the boss on this stuff, but the Velo does match the glossy piano black monitors that she was so pleased with. I know, looks should not be the prime concern nor is it in "my" room. The Velo was a good price and is small and looks like a set. It does bring up a question of hifi journalism. I have no real reason to trust HiFi Choice mag but admit that when I saw the "Product of the Year Award" in the July 07 issue and the sub on AudiogoN. I have been wanting to post the question of magazines here. In any case, it did influence me but I usually do hold critics esp music with a grain of salt. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 5259 Registered: Feb-05 | It's not like REL or ERA but different altogether. Very tight high power subs...good choice for music (I know I said that already). |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 202 Registered: Jul-07 | I have not heard the REL or ERA. It is not easy to shop in the boon docks! Just have to give it a try. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 5262 Registered: Feb-05 | I think you'll be pleased.... |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 206 Registered: Jul-07 | I am getting nervous. Big flurry of emails while we cemented the deal Fri Aug 17 when I did the paypal order. Now Mon eve Aug 20 and still no response from seller. I have requested a shipping date. He is observing silence. When should I get really worried?? |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 208 Registered: Jul-07 | Yes, finally got the shipping notice Aug 21. |
Gold Member Username: NuckPost Number: 8385 Registered: Dec-04 | Warm up the dogsled, Kevin. Airport pickup. |
